Activity › Forums › Avid Media Composer › Timecode Burn-in
  • Timecode Burn-in
    Posted by Mark Seymour on January 22, 2010 at 11:39 pm
    I am adding a burn-in showing feet and frames using the Timecode Burn-in effect found in the Generator category. I want to start the number sequence as 0000+01 not the 0000+00 that is default. I can do this using the Illusion FX Timecode effect but it requires time consuming rendering where the Generator Timecode Burn-in does not. I am using Media Composer v 3.1.3. Does anyone know if Media Composer version 4 allows you to offset the numerical display similar to the Illusion effect? Or is there a way to apply the offset that I am missing?
    Job Ter burg replied 16 years, 8 months ago 2 Members · 1 Reply
  • Job Ter burg
    January 23, 2010 at 8:48 am
    You can set the start number for the sequence (which is where the Generator is getting the number from now). Click in the timeline once, then hit CTRL-I or CMD-I. Set the start number for the sequence.
