Activity Forums Apple Final Cut Pro Legacy Timecode Breaks in FCE 2
  • Timecode Breaks in FCE 2
    Posted by Kreative Kuh on December 3, 2005 at 3:39 pm
    This post may appear twice as I thought I sent it last night but is not on the board this morning.
    I am having trouble capturing footage because of a timecode break. I have checked the “abort on dropped frames” box in User Preferences as suggested by the manual. The weird thing is that I was able to capture the exact same footage a couple of days ago (why I am doing itagain is a longer story). This isn’t the first time I have had the problem. Can anyone help me out?
    Gunleik Groven replied 20 years, 9 months ago 5 Members · 9 Replies
  • 9 Replies
  • David Battistella
    December 3, 2005 at 4:41 pm
    Why not try logging arounf the breaks. To do this start any clip 4 to 5 seconds after a break and end a clip at least 3 seconds before a break. This forces FCP to capture what you have selected.
    It takes a bit loner but is a smoother way to go.
    David
  • Kreative Kuh
    December 3, 2005 at 6:02 pm
    The clip I’m trying to get is very short and between the breaks. But I’ll play with it. But I guess my larger question is whehter this is a problem that arises so frequently that I should just assume it is going to happen on a regular basis. That’s what seems to be the case now. And if that is true, do all versions of FCE do it? Does FCPro do it?
    Another question is whether there is something I can do to avoid the breaks in the first place. Is there something about starting and stopping the camcorder in certain ways that causes this to happen?
  • David Battistella
    December 3, 2005 at 6:48 pm
    Kevin,
    You shoudl always be rolling 5 to ten seconds of tape before and after a take just to avoid these problems altogether.
    THis is a common problem with the stop start button and itchy fingers hitting the button saying “go” without proper tape rollup.
    For now,
    just use capture now with dec control set to NON CONTROLLABLE DEVICE, cue the tape to before the break, hit play and capture away.
    David
  • Tom Wolsky
    December 3, 2005 at 7:17 pm
    The timecode breaks warning can have spurious causes. Your complete system set-up would be helpful, camera/deck, drives, computer, how everything’s connected, the settings on the tape, and the settings you’re using to capture. Did you update to 2.0.3 BTW?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Enzo Tedeschi
    December 3, 2005 at 10:13 pm
    And just to add to that, Kevin, if you go back on your camera while you are shooting and play back a take to see what you have and then continue shooting, this can also create tc breaks. After previewing your take, make sure you overlap a second of the last take and go over it. This will help ensure continuous timecode.
    And if you leave ample time after your take has ended (as David had suggested), then you won’t stress about losing a second before the last camera-stop.
    e.
  • Kreative Kuh
    December 4, 2005 at 4:28 pm
    Just to be clear: whenyou say “go over” the last second or two of the previous take, you mean film over it, right? I seem to recall the first time I had this problem I did exactly what you described. There was a little blank space between takes and that’s where (I think) the problem arose.
  • Kreative Kuh
    December 4, 2005 at 4:30 pm
    Is “dec control” something in FCE, or something on the camera?
  • David Battistella
    December 4, 2005 at 8:16 pm
    Tom is right.
    Many camera’s have built in end search, so that if you hit the button after watching a take it takes you to the last TC and continues to record from there.
    David
  • Gunleik Groven
    December 5, 2005 at 8:02 pm
    Deck controll is what controlls the deck or camera – thus a feature of the program.
    In FCP you can set capture presets to “uncontrollable device” f.ex. to capture across narrow timecode breaks.
    That is not to say you should try to avoid the problem altogether, following the suggestions from the other gentlemen. But as you obvioussly need that tiny clip, disabling deck controll might do the trick.
    If you have some other way to digitize the footage (Like advc-100 or 110), you could go through the analogue out on your deck/camera and capture through that.
    I’ve had to do that myself on a bad tape where the TC was totally messed up.
    Good luck!
    Gunleik
