Activity Forums Apple Final Cut Pro Legacy Timecode Breaks
  • Timecode Breaks
    Posted by Brian Bradley on October 22, 2005 at 4:16 am
    I’m trying to capture footage off of a tape that has major timecode breaks. I’ve been unsuccessful in using the Capture Now option. Everytime I try capturing an error message pops up alerting me of the timecode breaks. Is there a way I can turn off this warning option and just capture with timecode breaks?
    Brian
    Rajesh Bhanushali replied 20 years, 11 months ago 3 Members · 2 Replies
  • Thaxter Clavemarlton
    October 22, 2005 at 4:32 am
    If you simply don’t care about the TC (kind of dangerous thinking) switch to “Non-Controllable Device”, play the tape manually, and use Capture Now.
    Better solution is to make a new copy of the errant tape.
    Connect any two DV units (camcorders or decks) via FireWire and just make a new dub of the old tape to a new one.
    The new copy will be “first-generation quality” but it will have a new continuous Timecode.
    Then, just capture from the new copy.
    Takes a bit more time this way, but having reliable TC can save you many problems in an edit situation.
  • Rajesh Bhanushali
    October 22, 2005 at 5:53 am
    Thats one way which Thax mentioned.
    The other way which I do , when i capture with timecode breaks is as follows
    Go to “User preferences”
    Uncheck the [Abort capture on dropeed frames ] option
    and [On timecode break:] option ;- switch to “Warn after Capture” instead of “Abort capture”
    Hope the same works for you too 🙂
    Regards.
    Raj.
