Activity › Forums › Adobe Premiere Pro › TimeCode and Rendering Question
  • TimeCode and Rendering Question
    Posted by Matt Chapman on June 24, 2015 at 8:00 pm
    Hey Gang-
    I have completed my first edit in Premiere, at least my first 24 track in-depth one. Huzzah!
    One question I had is how to apply a timecode burn to my output across the WHOLE timeline.
    I made an empty title and put it on the top layer and applied the timecode effect. A couple questions:
    there wasn’t a 23.976 fps option in the dropdowns which was weird. Also when I did this the timecode started at 54:54:00 and then counted down?
    The option as to where to start the timecode was greyed out.
    When rendering, is there a way to save all the pre-rendered audio? It seems to take a long time rendering the audio each time.
    Chapman
    Andrew Kimery replied 11 years, 3 months ago 2 Members · 1 Reply
  • Andrew Kimery
    June 24, 2015 at 8:16 pm
    When go to export it you can apply a TC effect in the export window itself (it’s under the Effects tab near the middle of the window). You can set it to read the TC from the timeline or it can generate its own TC.
