Activity › Forums › Apple Final Cut Pro Legacy › timecode
timecode
Posted by Dennis Allen on June 2, 2008 at 5:29 pmtimecode appears on deck but not in log and capture window. only zeros appear.
Dennis Allen replied 18 years, 3 months ago 3 Members · 8 Replies -
Jeremy Garchow
June 2, 2008 at 5:35 pmPlease provide more information such as versions of everything and if you have any capture cards. What type of deck and how it’s connected will help as well.
Dennis Allen
June 2, 2008 at 5:42 pmfcp 5.1.4 jvc deck (consumer, but worked in the past) connected through firewire, on apple g4
Jeremy Garchow
June 2, 2008 at 6:11 pmDennis, I can’t really help you until you tell me exactly what you have tried and what exactly is going on.
What do you mean zeros appear? Imagine that I can’t see what you are doing, and you shouldn’t have to imagine too hard because I’m not there, then try and describe the problem to me.
Tell me exactly the steps you have taken to get where you are.
Jeremy
Gary Adcock
June 2, 2008 at 9:37 pm[Dennis Allen] “fcp 5.1.4 jvc deck (consumer, but worked in the past) connected through firewire, on apple g4 “
Dennis
Jeremy is correct, how do you expect us to answer your questions if you are not going to assist us with your setup and what you are trying to do.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD -
Dennis Allen
June 3, 2008 at 6:48 amsorry about that. I am trying to capture mini dv off of a consumer JVC deck (mini dv and vhs combo.) The timecode displays in the deck but in the log and capture window (fcp 5.1.4) where the in and out point timecode displays are, there are only zeros; 00:00:00:00
Dennis Allen
June 3, 2008 at 4:15 pmno, timecode does not update, nor does it mark an in or an out point. also, the space bar does not start or stop the deck
