Activity Forums Audio Timecode
  • Timecode
    Posted by Doug Cwiak on May 1, 2013 at 9:25 pm
    Hello Everyone!
    New here and to many things in the audio realm. Quick question – I am using a
    Blackmagic camera and just came into the possession of a Tascam HD-P2. I read
    the manual but I’m still not sure how to sync the two with timecode. Anybody know
    of a tutorial for a newbie or can you explain?
    Michael Paul replied 13 years, 4 months ago 2 Members · 3 Replies
  • Michael Paul
    May 1, 2013 at 11:18 pm
    I don’t think the BMC outputs SMPTE Timecode, so you can’t sync directly with the camera.
    Plural Eyes is your friend.
    Otherwise, you could try the “poor man’s timecode” method of running an external TC generator into the TC Input of the HD-P2 and into one of the audio inputs of the BMC. Bring the video files into Avid MC and use a feature called “Read Audio Timecode” to create a virtual timecode timeline which you can then sync your imported wav files into.
    Michael Paul
    Location Sound Corp
  • Doug Cwiak
    May 2, 2013 at 12:45 am
    Michael – Thanks for the info. I don’t know if it helps any but
    on the BlackMagic site is say:
    “The Blackmagic Cinema Camera records “time of day’ timecode based on the time and date settings in the camera. This can be accessed via the touchscreen menu. The SDI output of the camera also carries RP-188 timecode.”
    Does that help me any?
  • Michael Paul
    May 2, 2013 at 3:35 pm
    Unless you can figure out an economical way to strip the TC out of the SDI feed and convert it into standard SMPTE Timecode, then no, it doesn’t help you.
    The sound Devices PIX240 will accept TC through the SDI feed, but that sort of eliminates the need for the HD-P2
    Michael Paul
    Location Sound Corp
