Activity Forums Adobe After Effects time warp
  • Posted by Alex Harding on April 1, 2006 at 2:46 pm
    hi there
    im trying to use the new timewarp in afx 7 pro. im used to kronos in shake, which this is based on i believe?
    i cant work out how to get it to alter the duration of a clip, however. i can make the clip go slower, but i end up with a clip where the first few frames are stretched out to take up the original duration.
    i want a clip that is, say, 30 frames, to become 90 frames at 33% speed
    make sense?
    cheers
    Andrew Kramer replied 20 years, 5 months ago 3 Members · 3 Replies
  • David Bogie
    April 1, 2006 at 5:15 pm
    Use time stretch instead of timewarp.
    bogiesan
  • Alex Harding
    April 1, 2006 at 5:48 pm
    well.
    time stretch doesn’t do motion analysis and uses inferior frame blending. i wouldn’t need to use after fx at all for this if frame blending was sufficient.
    of course, you already knew this because you have read the “freakin manual”
    cheers,
    alex
  • Andrew Kramer
    April 2, 2006 at 8:12 am
    Use timestretch and set the frame blending mode to “pixel motion” and it uses the frame interpolation to create intermediate frames. Not frame blending.
    Good luck
