Activity Forums Adobe After Effects Time Warp makes effect dissapear!
  • Time Warp makes effect dissapear!
    Posted by Jacqueline Cheval on March 6, 2011 at 10:54 am
    I am quite a beginner in AE and struggling with the following problem:
    I got a Ps stills layer which I applied a scatterize effect to, and I want to change its speed using time warp – slowmo – fast and slowmo (time remapping doesnt work with stills).
    It wouldnt let me, as soon as I apply the time warp effect, the scatterize effect disappears! please help, I have been looking for the answer everywhere.
    Jacqueline Cheval replied 15 years, 5 months ago 2 Members · 4 Replies
  • Joey Foreman
    March 6, 2011 at 3:24 pm
    Precompose the layer, then apply the Scatterize effect in the precomp. Apply Timewarp in the main comp.
    Joey Foreman
    Editor/Compositor/VFX Artist
  • Jacqueline Cheval
    March 6, 2011 at 6:23 pm
    Thanks for the reply.
    That (nearly) worked, but shortly before the effect comes to an end, it enlarges and distorts for the length of one frame. Any idea?
  • Joey Foreman
    March 6, 2011 at 11:56 pm
    Actually Time Remapping should work just fine with a still, as long as you animate it in the precomp.
    I don’t use Time Warp much, precisely because of its tendency to cause distortion and artifacting.
    Joey Foreman
  • Jacqueline Cheval
    March 20, 2011 at 4:46 pm
    Thanks, I tried that in the first place, but felt that I didnt get the
    control over the time as good as with time warp. It kind of worked to
    get the “speed – slowmo – speed” effect though I have to admit that
    the way keyframes behaved in time warp didnt make sense to me as eventhough I had the exact same keyframes in each and every layer,(both main comp and pre-comp), the layers responded very differently and besides normally, an interpolation between 2 keyframes happens faster when dragging them closer together, here it was slower.
    Again, thanx for the pre-comp advise.
