Activity Forums Avid Media Composer Time warp distorting image
  • Time warp distorting image
    Posted by Danny Baron on July 14, 2013 at 1:19 pm
    I am adding Timewarp to slow down a shot. Inside the shot an actor is moving his hand. His hand waves in front of a bush. The time warp is distorting the image all around the moving hand, particularly the bush behind it. I tried at 50% and 25%. The slower it is, the worse it is, but it is still present at 50%.
    Any idea why this may be?
    Danny
    Danny
    Josh Dutton replied 12 years, 6 months ago 3 Members · 3 Replies
  • Michael Phillips
    July 14, 2013 at 5:39 pm
    Timewarp with FluidMotion recreates frames based on pixels and motion vectors in the image. Artifacts usually occur when something is being revealed that wasn’t in the previous frame. This is what the vector map editor is for – a bit daunting, but you will see all the vectors and movement as color maps and can keyframe the mesh as needed.
    Michael
  • Danny Baron
    July 15, 2013 at 12:56 pm
    Michael, thanks.
    Danny
  • Josh Dutton
    February 23, 2014 at 9:18 am
    I made a tutorial of what I do so far for this problem.. hope it helps
    https://youtu.be/5nAeu96n8Ok
