Activity Forums Adobe After Effects time warp and directional blur help
  • time warp and directional blur help
    Posted by Bodybuildingbs on August 2, 2006 at 2:43 am
    Hello
    I have a footage clip that is 33 seconds long. I imported it into a new comp in AE and applied time warp..now I like to reduce the speed to 50% but the rendered comp doesnt show the entire video clip it cuts off like the last 3 seconds after it plays the 33 seconds that the video clip original is composed of..I tried setting the comp time longer but nothing.
    Please advise.
    Ben The camera guy replied 20 years, 1 month ago 2 Members · 1 Reply
  • Ben The camera guy
    August 2, 2006 at 9:02 am
    have you tried using time remapping? is that the same as time warp? time remapping allows you to set keyframes that say to play a certain point in time of a layer at a certain point in time of your comp…if you wanna slow things down to 50%, bring ur 33 sec thing into a 66 sec comp and enable time remapping on the layer…then go to the end and set a keyframe for 33 sec in the time remapping property…this should do it for ya…
