Activity Forums Maxon Cinema 4D Time Track problems
  • Time Track problems
    Posted by Adam Taylor on October 28, 2010 at 7:25 pm
    I have a scene that includes an animated mograph cloner moving along a spline, whilst a camera is animated to pass close by the cloner.
    I want to slow everything down (almost bullet time) as the cloner objects pass close to the camera, and i have been told the best way is to use a Time track.
    However, I cannot make head nor tail of how to do this! The online docs dont help and several hours of web searching has revealed very little that refers to this function.
    Please can someone explain how i can achieve this effect?
    I’m using r12studio version on a mac.
    thanks
    Adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    Ryan Hamilton replied 15 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Adam Trachtenberg
    October 28, 2010 at 8:34 pm
    It’s pretty easy:
    1. Select your align-to-spline position track in the timeline;
    2. Timeline>File>Add Special Track>Time Track;
    3. Select your align-to-spline track and look in the attributes manager. You’ll see a “Time Track” link box. Drag the time track from the time line into that box.
    No you can animate the time track and it will adjust the speed of your position track.
    You can use the same time track for multiple other tracks as well.
  • Adam Taylor
    October 28, 2010 at 9:11 pm
    thanks Adam, i can see what you’re suggesting and it makes sense but i must be doing something wrong because i cannot get the process to work.
    Here’s what i’m doing….
    open Timeline – its empty, so I dragged the align to spline tag into Timeline. This seems to automatically add a Time track. Although the attributes mgr shows the time track link box, its greyed out so i cannot drag the time track into it.
    Adding a special track/time track just ads another time track, but again i cannot drag it into the attributes mgr.
    Any idea what i might be doing wrong?
    adam
    Adam Taylor
    Oldham, UK
  • Adam Trachtenberg
    October 28, 2010 at 10:50 pm
    Well, first you should animate the align-to-spline position parameter by creating keys at your desired start/end frames. That will create an animation track for it, which is not the same thing as a time track.
    Then, with that align-to-spline track selected, create your time track. Then you should be able to drag the time track into the other track’s time track link box.
    OTOH, if you’re *just* animating the align-to-spline tag’s position, it might be easier to skip the time track and work with original track’s f-curve instead.
  • Adam Taylor
    October 29, 2010 at 11:48 am
    Hi Adam,
    weird – tried this with the same file but on my Tower instead of the laptop, and it seems to be working!
    What i can’t figure out though, is this – I want to slowmo the entire scene for a section in the middle, not just the align to path.
    I actually have several different align to paths (flying object / camera / camera target) – so rather than trying to adjust each one, i want to apply the time effect to everything…
    in the meantime – thanks for the advice…i’m a lot closer than i was before it!
    adam
    Adam Taylor
    Oldham, UK
  • Adam Trachtenberg
    October 29, 2010 at 1:59 pm
    That’s the nice thing about the time track; you can assign the same one to multiple objects/parameters so you can affect the whole animation with one curve.
  • Adam Taylor
    October 29, 2010 at 2:03 pm
    i think this needs a lot more head scratching, because i cannot get anything other than the camera to respond to the time track, even though i have it assigned to each parameter.
    I’m going to have to start over i think.
    your advice has been very helpful – thanks
    Adam Taylor
    Oldham, UK
  • Ryan Hamilton
    December 4, 2010 at 7:56 am
    Hey Folks,
    I’m also working on figuring out some time track applications. Once I have one applied and as instructed above; select it and drag it into the ATmanager where it says Time Track I get blocked. At the bottom of the ATmanager where it says Time Track and has the link space, that is greyed out so I am not able to drag anything in.
    Cheers.
