Activity › Forums › Adobe After Effects › Time Stutter on one layer
  • Time Stutter on one layer
    Posted by Lucy-rae Naylor on September 17, 2019 at 7:31 pm
    Hello lovely people! I’m currently working a project which has a ‘time stutter’ on a footage layer. At the moment I’ve just duplicated 2 frames of the layer to achieve this effect, but as it’s going to be a working template I’d like to have it one layer (maybe using time remap?) to keep it as clean as possible. Does anyone have an idea how I can achieve this?
    How the effects looks on my timeline..
    https://ibb.co/c2g57Ng
    Lucy-Rae
    Lucy-rae Naylor replied 7 years ago 2 Members · 2 Replies
  • Walter Soyka
    September 17, 2019 at 10:12 pm
    Yes, time-remapping will do the trick. Consider using hold keyframes on each frame (to prevent a “rewind” effect if the footage timebase is different than the comp timebase).
    You should probably do the time remapping on a comp, so it’s clear to the user how long the footage needs to be to work in the template.
    Here’s a quick example:
    13727_timeremap.aep.zip
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Lucy-rae Naylor
    September 19, 2019 at 9:37 am
    Thanks Walter!
    That’s worked for me, thanks for the AE file. Helped me understand it all.
    Lucy-Rae
