Activity Forums Adobe After Effects time stretching footage that goes in & out of focus
  • time stretching footage that goes in & out of focus
    Posted by Hillary Knox on February 14, 2012 at 8:29 pm
    Trying to use AE & Kronos to manufacture some slo-mo. Considering the time that I’ve invested in it (very little), the results so far have ranged from more-than-acceptable to pretty great…until now.
    I have a clip (shot on 5d) that’s an ECU of an actor’s face – the focus is super shallow and the actor is rocking back & forth, face going in & out of focus.
    I’m no expert slo-mo manufacturer, and I don’t know if there is a trick to getting this to work better. I’m only trying to slow the footage down 50%, but I keep getting some really weird morph-y looking stuff happening in the large facial surface areas i.e. cheeks. I thought about subdividing the clip into in-focus and out-of-focus sections & slowing those sections independently, but I don’t want to do any more wheel reinvention than is necessary. Is there a standard trick for dealing with this?
    Thanks.
    Hillary Knox replied 14 years, 7 months ago 2 Members · 2 Replies
  • Michael Szalapski
    February 14, 2012 at 11:00 pm
    Is there a reason you can’t reshoot with the actor moving at the speed you want (or the camera at a higher shutter speed)?
    By how much are you attempting to slow it?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Hillary Knox
    February 15, 2012 at 5:30 pm
    Thanks for the replies.
    Short answer: thanks. it totally worked for what I need
    Long answer: I did 4 versions (2 of them might be superfluous): 2 versions using Time Remap only, 2 versions using Time Remap plus Timewarp. I can *maybe* see a micro-difference with Timewarp in addition to Remap, but it could just be psychological.
    I did one batch with the Frame Blending set to Pixel Motion & precomped that prior to doing the Time Remap/Timewarp just to see if it would make any difference. Again, maybe micro difference, maybe not. The only reason I did that was because in a Kronos tutorial I saw, that was the first step before they Kronos-ed the footage & I thought it might be worth a try. Don’t ask me what it actually does.
    Again, thanks for the help.
