Activity › Forums › Apple Motion › Time stretch on entire project
  • Time stretch on entire project
    Posted by Benjamin Lancaster on April 3, 2010 at 2:23 am
    So I’ve created a Motion project with lots of different things flying around. Now, unfortunately, I need it three times as long as it is. Is there an easy way to stretch the whole project without resorting to dropping the keyframes to 10? I’d really like to keep the whole thing as is, just add frames proportionately throughout the project.
    Thanks, and sorry for the noob question.
    Mark Spencer replied 16 years, 5 months ago 3 Members · 2 Replies
  • Andy Neil
    April 3, 2010 at 6:36 am
    The short answer is no. You can group all the layers in your project, and clone the group then apply a speed change to the clone, but I doubt that’s going to suffice.
    You could also export the project, reimport and apply a timing behavior to the baked movie, but if you make changes, you have to re-export.
    Andy
  • Mark Spencer
    April 3, 2010 at 2:23 pm
    One thing that can help in this process is the box tool in the Keyframe Editor – with it you can time-stretch a group of keyframes quite easily. Unfortunately you can’t do it on all the keyframes in your project at once, but it can be quite helpful.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
