Activity Forums Maxon Cinema 4D Time stretch in cinema 4d?
  • Time stretch in cinema 4d?
    Posted by Chad Demoss on June 30, 2016 at 9:16 pm
    As usually I googled this before asking here.
    What I need to do I speed up my animations by 50% except theres a 3d motion tracking camera in there that I don’t want to change the time on.
    so I watched a tutorial that showed me under functions “move/scale” this worked but it deleted some of the keyframes that are 1 frame apart. attached is a screengrab
    before I scaled the keyframes
    https://chaddemoss.com/keyframe/keyframe.jpg
    after I deleted keyframes
    https://chaddemoss.com/keyframe/deleted_keyframe.jpg
    what do I need to do to scale all the keyframes except the motion tracking camera?
    Adam Trachtenberg replied 10 years ago 2 Members · 3 Replies
  • Adam Trachtenberg
    July 1, 2016 at 2:03 am
    I would use a time track.
  • Chad Demoss
    July 1, 2016 at 5:51 pm
    Thanks adam
    I’m not sure what i’m doing wrong with the time tack but I have 100 objects animating more then just position scale and rotation and my attempt didn’t work. The move/scale seemed to work except for the fact that that it merged keyframes that were right next to each other. is there a way of telling Cinema 4d to not merge keyframes?
  • Adam Trachtenberg
    July 2, 2016 at 10:11 pm
    I did a quick video tutorial on the time track. Hopefully this will help: https://youtu.be/q6AuonzrDJ4
