Activity Forums Apple Final Cut Pro Legacy time-senistive sync EMERGENCY!
  • time-senistive sync EMERGENCY!
    Posted by Steven Austin on June 8, 2010 at 6:13 am
    CRUCIAL and ULTRA time-sensitive emergency here…
    Tomorrow (6/8) at 7:30 pm the director of the feature I’m cutting is arriving for a look. Today something STRANGE happens when I open & use the FCP project file!!!!
    I get the “media start & end” warning, and it’s out of sync by a few frames! Yet on the timeline, my video & audio trax are in sync (i.e. no red + or – frame icons). My settings have remained the same since the project’s inception. 35mm negative was telecined at 29.97 and reverse telecined to 23.98, standard NTSC for off-line cutting. Codec is DV/DVC Pro NTSC.
    I am also using some actual video (just for temp establishing shots) which were ripped from DVDs at 29.97. (These were provided — I have no access to the DVDs).
    I’ve trashed prefs… reconnected all media, but nothing sets it straight. This does NOT occur on other FCP projects, yet all previous versions of this project are also out of sync.
    Everything has been working out OK until the NIGHT BEFORE I have to screen my cut. If there’s anything you can help with, please do so!
    Many thanks!
    Bouke Vahl replied 16 years, 3 months ago 9 Members · 17 Replies
  • 17 Replies
  • Michael Gossen
    June 8, 2010 at 6:58 am
    Do you have a back-up of the project file? What about a backup of the media? My first gut though is that it isn’t something to do with the project, but with the media instead. Has it moved, changed, etc in Finder? Are you the only one accessing this media?
    Michael Gossen
    Helium Digital Media
  • Jeremy Garchow
    June 8, 2010 at 12:33 pm
    Why did you get a media start and end errror? What did you do to get it?
  • Steven Austin
    June 8, 2010 at 3:23 pm
    I didn’t back up this project file, though I do have earlier versions of it. It’s set on save every ten minutes. NOW I noticed an additional problem…. some of the shots literally change into other shots at arbitrary times. Example, one unbroken, solid “block” of video on timeline appears to be accessing two different shots. I can reconnect these shots and the problem disappears, but this is an action movie and there are hundreds of shots to cull through!!!!
    “In modern action films, the only people who work up a sweat are the editors.” — Roger Ebert
  • Steven Austin
    June 8, 2010 at 3:25 pm
    Wish I knee WHY I get media start/end error flag, I don’t have a clue. It happens when I boot up the project. Prefs have been trashed, all media reconnected. I am the only one with access to the external drives, there are two.
  • Bj Ahlen
    June 8, 2010 at 3:31 pm
    Sounds like time to give this a try.
  • Jeremy Garchow
    June 8, 2010 at 3:32 pm
    [Steven Austin] “Wish I knee WHY I get media start/end error flag, I don’t have a clue. It happens when I boot up the project. “
    Can you please give the exact error?
  • Bouke Vahl
    June 8, 2010 at 4:00 pm
    or this:
    https://www.videotoolshed.com/product/41/fcpreconnect
    I suspect you have ingested a lot of files with same filenames to different folders.
    If so, FCP is reconnecting to the wrong files (as filenames are used twice…)
    hth,
    Bouke
    smart tools for video pros
  • Dean Goldsworthy
    June 8, 2010 at 4:57 pm
    Since you are working on a feature I’m going to assume you have a rather long sequence or sequences. You may want to try:
    1. Having ONLY one sequence open at a time.
    2. Sub-divide that one sequence into smaller sequences. ie show the producer/director 10 minutes at a time.
    3.Try saving the smaller sequences as their own projects to help cut down on the number of clips in it.
    I have run into times when it seemed FCP just had trouble keeping up with lots of open clips.
    Again since everything was stable and just now is showing trouble I would look to see how full your media drives are. If you are over 75% you may be having trouble.
    Hope this helps.
  • Steven Austin
    June 8, 2010 at 11:19 pm
    Well, I had to perform a compete re-install bu that did the trick. Now I am only six hours behind & the director is set to arrive!!! 🙁
    THanks, everyone.
  • Tom Brooks
    June 9, 2010 at 1:51 am
    Disk Warrior is always a good bet, too. Quick and easy. Worth a try before more drastic measures, but usually a media drive will show signs of major file system corruption rather than mysterious things like you described.
