Activity Forums Adobe After Effects Expressions time reversing keyframes
  • time reversing keyframes
    Posted by Criis Daw on May 12, 2008 at 11:12 am
    Hi
    Can anyone please help with this………..
    I have several rotating discs and i would like to add a drop shadow to, which doesnt rotate with it.
    I have it that the drop shadow appears stationary when i copy the rotation keyframes of the disc into the angle of the drop shadow and time reverse them.
    I was wondering how to write an expression to acheive the same.
    I would save me a lot of time and make the whole thing a lot more editable.
    Chris
    Criis Daw replied 18 years, 3 months ago 3 Members · 6 Replies
  • Darby Edelen
    May 12, 2008 at 3:26 pm
    I believe the expression should be:
    -transform.rotation
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Dan Ebberts
    I think I see what you’re after. Try adding this expression to the “Direction” parameter of the drop shadow:
    value – rotation
    Dan
  • Criis Daw
    May 12, 2008 at 3:31 pm
    wicked .. it works.
    and something as simple as a minus sign !! brilliant
    thanks alot
  • Criis Daw
    May 12, 2008 at 3:38 pm
    both ways worked…
    thanks very much
  • Darby Edelen
    May 12, 2008 at 4:38 pm
    Dan’s is better =) You can change the value of the angle property to change where the drop shadow falls with his expression… It’s all in the details!
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Criis Daw
    May 12, 2008 at 5:02 pm
    i was doing the same with yours by typing the value in the script.. As i wanted it to remain (apparently) motionless.
    I think there is more to play with here.. (isnt there always )
    thanks for you help
    Chris
