Activity › Forums › Adobe Premiere Pro › Time remapping/slow motion?
Posted by Joel Pollock on July 2, 2013 at 12:49 pmMy footage is all 29.97. Will I have problems getting slow motion out of it? I heard if you want slow motion to look smooth you need to shoot in 60. Thanks for any help or tips!
Joel Pollock replied 13 years, 2 months ago 3 Members · 3 Replies -
Angelo Lorenzo
July 3, 2013 at 4:11 amWhen using slow motion in any form, it’s better to use sources with more frames. It’s like the temporal (time based) version of image resizing: it’s easier to get a great result if you increase the size of an 8mp image by 10% than if you were to do the same to a 400×600 image.
A computer program can only guess at what frames to create and if it’s given higher framerate material to begin with, this process is easier and returns a better result.
Shooting at a higher framerate to begin with also creates frames with less motion blur which improves this guessing process as well.
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter -
Fred Nelson
July 4, 2013 at 12:07 pmIt depends what you mean by “problems”. By all means you will be able to get slow motion by using the Time Remap function. Granted, it will be less fluid and just a tad more “jerky” than using 60 fps footage – but it will work. Cheers!
