Activity › Forums › Adobe Premiere Pro › Time remapping?
Time remapping?
Posted by Hector Melendez on September 9, 2008 at 6:24 amThere are any tutorial how to use Time Remapping? I had tried may times and can’t move the speed counter thru the clip.
I want to do multiple speeds in a clip.thanks in advance
Jon Barrie replied 18 years ago 3 Members · 4 Replies -
Jon Barrie
September 9, 2008 at 8:35 amHow many editors does it take to change a light bulb?
http://www.jonbarrie.net -
Hector Melendez
September 9, 2008 at 4:47 pmDo I need a PHD? Can’t follow the tutorial! Can’t make the points to decrease or increase speed. Either can’t see a black line… only a yellow one (in the timeline) but in the effects control is black but in the tutorial never mention where to you make the adjustments. I cut the clip and leave space ahead to be sure is not a problem.
Have to be a trick or something I’m omitting.Remember the days when I tried to follow Encore tutorials. Can remember the the host name) but was impossible to follow by me. Then I discover the steps by myself and was sooo easy. The training conductor was confusing and to step over and easy task. Could be same thing is happening here
Jon Barrie
September 10, 2008 at 2:56 amYou do the time remapping in the timeline. Once you set the keyframes with the arrow and holding ctl or cmd (mac) you pull down for slower or up for faster the yellow band in the clip when its in the timeline. the clip wil dynamically sdjust the position of the following keyframes you made to compensate the speed difference.
– Jon Barrie 🙂How many editors does it take to change a light bulb?
