Activity Forums Adobe After Effects Expressions Time Remapping with Markers
  • Time Remapping with Markers
    Posted by James Ronan on November 29, 2016 at 11:00 am
    Hey
    I’ve seen some great expressions for animating with markers, wondering if anyone could share any more knowledge…
    I’m building a project where: Multiple layers quickly wipe on screen (1.5 seconds), come to a slow pan(10 – 30 seconds), then quickly wipe off again (1.5 seconds). The amount of time they slowly pan is going to change every time.
    If I precomp everything, is there a way that I can time remap it with two markers, and write an expression that says everything before the marker IN is normal speed, and everything after marker OUT is normal speed.
    marker IN will go 1.5 seconds into the comp. marker OUT will be adjustable, but directly after it will trigger the ending wipe out phase of the animation.
    Hope that makes sense?!
    Thanks so much
    James
    James Ronan replied 9 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
