Activity Forums Adobe After Effects Time-Remapping Problem
  • Time-Remapping Problem
    Posted by Tom Sven on March 5, 2007 at 3:28 am
    Hi All.
    I have been working on a project in which I have masked out an object and now want to slow the begining using time-remap to make the different parts of the composite fit a little better. However when I apply the time-remap and change the timeing of the video, the mask is interpolating the slower in between keyframes that don’t match the video. I know I could render the mask and import the footage then apply the time-remap, but i have to figure theres a sexier way. Does anyone have any tips?
    Tom
    Mylenium replied 19 years, 6 months ago 2 Members · 1 Reply
  • Mylenium
    March 5, 2007 at 6:56 am
    No. You need to render. If you apply the time remap to the pre-comp itself, AE will always try to interpolate keyframed data instead of working on the pixels. It’s one of the core principles (and mostly useful, as it maintains quality). If you use the timewarp effect instead of Time Remapping, that limitation is no longer valid, so give that a try (if you really must keep everything “dynamic” and editable).
    Mylenium
    [Pour Myl
