Activity Forums Adobe After Effects Time remapping makes image unstable
  • Time remapping makes image unstable
    Posted by Maxime Marquis on August 14, 2009 at 2:31 am
    I exported a clip from FCP (ntsc, 720X780, 29,97fps) to AE because I needed to do some time remapping. The trouble is, after I slow down a segment of a shot, the image is unstable (it keeps on jumping faintly but rapidly). It’s obvious on the top and bottom edges of the image (it was shot squeezed to be letterbox). In fact, I don’t know if the image jumps or just the letterbox bars. Any clues?
    Thanks in advance
    Liridon Agushi replied 17 years, 1 month ago 2 Members · 1 Reply
  • Liridon Agushi
    August 15, 2009 at 5:34 pm
    Try to configure the 32 bps or 64bps, then the quality will be high, if it doesn’t work try to make the remapping in Adobe Premiere, maybe it can help you.
    Liridon Agushi
    http://WWW.CREATIVEBOOKERS.COM
