Activity › Forums › Adobe After Effects Expressions › Time Remapping: Loop with Ping-Pong but also progress forward
  • Time Remapping: Loop with Ping-Pong but also progress forward
    Posted by David Potvin on February 28, 2013 at 5:56 pm
    I’m looking to have a clip play to a specific pattern of 3 frames forward, 2 frames back, 3 forward, 2 back, etc. so that the net gain in frames forward is actually only 1 for every 5 frames. (You could also look at it this way: the footage plays normally for 1 frame, then ping-pongs for 4 frames [2 forward, 2 back]). My composition’s framerate is 23.976.
    Here’s a chart to help you visualize what I’m trying to accomplish:
    TIME (in frames)(1/23.976 seconds) > Frame # from original footage
    0 > 0
    1 > 1
    2 > 2
    3 > 3
    4 > 2
    5 > 1
    6 > 2
    7 > 3
    8 > 4
    9 > 3
    10 > 2
    11 > 3
    12 > 4
    13 > 5
    14 > 4
    I’d like to use an Expression to create this effect. The pattern follows a series of 5: a, b, c, d, c. Then 1 is added to all values, and the pattern repeats. So I created the Expression below.
    AE doesn’t take issue with any of the syntax, but it’s still not working. Where have I messed up?
    Thanks in advance for any insight or reworking anyone can offer!
    timeToFrames(t = time + thisComp.displayStartTime, fps = 1.0 / thisComp.frameDuration, isDuration = false); //converts timecode to integer in frames
    var a = 0;
    var b = 1;
    var c = 2;
    var d = 3;
    var s = 0; //s represents the # of the frame from the original footage
    var g; //g will be the # of the frame from the original footage converted back to timecode format
    if(t % 5 == 0) {
    s = a;
    if(t % 5 == 1) {
    s = b;
    if(t % 5 == 2) {
    s = c;
    if(t % 5 == 3) {
    s = d;
    if(t % 5 == 4) {
    s = c;
    timeToTimecode(g = s + thisComp.displayStartTime, timecodeBase = 23.976, isDuration = false); //converts s into timecode format
    [g]; //states the value (in timecode format) of the original footage frame value
    if(t % 5 == 4) {
    a++; b++; c++; d++; //adds 1 to each variable once for every 5 frames
    David Potvin replied 13 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 28, 2013 at 6:45 pm
    I think this does it:
    f = timeToFrames(time);
    seg = Math.floor(f/5);
    phase = f%5;
    framesToTime(seg + ((phase == 4) ? 2 : phase))
    Dan
  • David Potvin
    February 28, 2013 at 7:10 pm
    Amazing! Very efficient. Thank you very much.
