Activity Forums Adobe After Effects Time Remapping issue (missing frame?)
  • Time Remapping issue (missing frame?)
    Posted by Phil Rad on August 14, 2013 at 9:24 pm
    I have created an animation that is 40f long and I want to loop it. I placed the animated Comp in my main Comp, added Time Remap with an expression of loopOut(type = "cycle", numKeyframes = 0)
    I lengthened the animation out so it loops and it does it just fine but at every 40th frame, it disappears for one frame and loops again. I have no idea what is going on and it’s driving me nuts.
    Any idea?
    Darby Edelen replied 13 years, 1 month ago 3 Members · 5 Replies
  • Todd Kopriva
    August 15, 2013 at 3:20 am
    Show a screenshot of your composition, being especially careful to show your time remapping keyframes.
    After Effects team blog
  • Darby Edelen
    August 15, 2013 at 6:26 am
    [Phil Rad] “I lengthened the animation out so it loops and it does it just fine but at every 40th frame, it disappears for one frame and loops again. I have no idea what is going on and it’s driving me nuts.”
    Go to the last keyframe on the time-remapping property. Then go back one frame (a shortcut key for this is Page Up). Add a keyframe there then remove the last keyframe.
    Make sure you do it in that order or it’ll mess up the time-remapping good.
    As far as I can recall this issue never occurred in older versions of AE but appeared sometime around CS4… or maybe that’s just when I started noticing it 🙂
    The last frame of a 40 frame composition is frame 39 (since the frames start from 0) but the time-remapping creates the last keyframe with a value of 40.
    This behavior only causes problems with compositions as the last frame of a footage item (movie) is simply repeated once the time re-mapping moves beyond it.
    To fully fix the loop you’ll also need to copy the first time-remapping keyframe and paste it one frame in front of itself.
    Gee, while I’m thinking about this maybe I should file this as a bug 🙂
    Darby Edelen
  • Phil Rad
    August 15, 2013 at 1:24 pm
    Here’s the sequence (character is blurred on purpose for this example).
    38f:
    39f:
    40f (goes blank):
    41f (starts the loop again):
  • Phil Rad
    August 15, 2013 at 1:25 pm
    It’s odd that I changed the expression to loopOut(type = "cycle", 0) and it seems as if issue went away???
  • Darby Edelen
    August 19, 2013 at 2:58 am
    That is odd because that expression should evaluate to literally the exact same thing as your original expression 🙂
    Darby Edelen
