Activity Forums Adobe After Effects time remapping in an ayato tutorial
  • Filip Vandueren
    June 8, 2005 at 10:09 pm
    OK, you’re blowing up two things,
    but you want the illusion that the second one forms itself from the debris of the first one:
    make the 2 animations as described.
    the 2d one, you precompose (moving all attributes into new comp)
    On that precomposed layer, enable time remapping.
    Select the two keyframes that automaticlally appear, and do a ‘reverse keyframes’
    Move the reversed layer a bit forward in time untill you have a nice overlap of the particles and it appears seamless.
  • Ponyack
    June 9, 2005 at 8:42 pm
    that got it…
    thnanks again
    ponyack
