Activity Forums Adobe After Effects time remapping in 6.5, layer doesn’t extend to infinite
  • time remapping in 6.5, layer doesn’t extend to infinite
    Posted by Graham Quince on June 20, 2005 at 2:09 pm
    Hmmm, i’ve come across a slightly irritating problem, and i wonder if its a setting that can be changed. i’ve recently upgraded to 6.5 and one of the things thaty seem different is that when i enable Time Remapping on a video layer, the possible length of layer doesn’t extend off the screen. i can time remap within the layer’s original length but can’t see how to make the whole thing longer?
    Does anyone have any ideas???
    Graham
    Filip Vandueren replied 21 years, 2 months ago 3 Members · 4 Replies
  • Steve Roberts
    June 20, 2005 at 2:30 pm
    Have you tried lengthening the host comp?
    Steve
  • Filip Vandueren
    June 20, 2005 at 11:05 pm
    Did you time-stretch the layer before you enabled Time-remapping ?
    The maximum length of a solid, still or time-remapped layer is indeed always the length of the comp (or the footage-duration if that’s longer), but that value get’s multiplied by the speed setting you’ve applied to the video.
  • Graham Quince
    June 21, 2005 at 8:07 am
    I did stretch the layer, but found that the time remap keyframes also extended. I’d be more than happy for the time-remapped layer to be the length of the comp, but unfortunately it falls short.
    It’s just strange because 6.0 didn’t do this 🙁
    Graham
  • Filip Vandueren
    June 21, 2005 at 11:39 am
    You’re better off setting the speed back to 100 % and then adjusting your keyframes to achieve the same (fester) effect.
