Activity Forums VEGAS Pro Time remapping
  • Time remapping
    Posted by Abhijyot Singh on June 12, 2008 at 3:53 pm
    Hi, in Premier Pro, for example, there is a time-remapping function. Is there is a similar thing for Sony Vegas? I have a scene where i need to ramp up the speed and then slow it down. I am aware that i could cut the portion of the clip out and then shorten the time it takes to complete by control dragging the sides. The problem with this is that the speed change in sudden whereas I am trying to make it ramp up. How would I go about doing this?
    Abhijyot Singh replied 18 years, 3 months ago 3 Members · 3 Replies
  • Terry Esslinger
    June 12, 2008 at 6:27 pm
    You could use a velocity envelope.
  • Steve Rhoden
    June 12, 2008 at 6:51 pm
    Indeed, Vegas has that feature and its called the velocity envelope.
    Select it by right clicking the video on the timeline.
    You can speed up and slow down video events to your liking as you described.
    Steve Rhoden
    TNX EFFECTS STUDIOS.
  • Abhijyot Singh
    June 12, 2008 at 10:03 pm
    Ok, thanks guys, also is there any way i could apply this to the audio and the video at the same time?
