Activity Forums Adobe After Effects time remapped 50fps footage creating uneven juddery playback
  • time remapped 50fps footage creating uneven juddery playback
    Posted by Jesse Richards on November 3, 2014 at 11:13 am
    Hi
    I have picked up an edit of some 50fps footage intended to be played back at 25fps for a slow mo look.
    Most of the shots work well but there are a few sections where the footage has been time remapped at different rates which is basically causing jumps in the frames (ie it will play frame 1 -3 -5 then 6 for example)
    The edit is locked and I just wondered if anyone had any ideas about how to counter this problem?
    Cheers
    Jesse
    Buddy Brett ramker replied 11 years, 10 months ago 2 Members · 1 Reply
  • Buddy Brett ramker
    November 5, 2014 at 6:17 pm
    If the footage is retimed to 50% then the playback should be smooth if said footage was really shot at 50p. Instead of retiming to the footage you can interpret it to 25p resulting in a natural slow down. Since you are trying to get slow motion playback with footage that was shot 50p I would avoid timewarp. That effect only works well with a good Hi C shot, and even then it requires a lot of fiddling and rendering.
    Best,
    Brett
