Activity › Forums › Adobe After Effects › time remaping problem
  • Walter Soyka
    July 13, 2015 at 7:55 pm
    There is an awful lot of change between those two frames. I don’t think there’s enough data there to make a convincing optical flow-based camera move.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Renato Zanardo
    July 13, 2015 at 8:09 pm
    I understand. Or much more frames, or less shift. As you say?
  • Walter Soyka
    July 13, 2015 at 8:38 pm
    [Renato Zanardo] “I understand. Or much more frames, or less shift. As you say?”
    Yes, a lot more frames with a lot less shift.
    Alternately, you might creating geometry that approximates the shapes in the scene and projecting the footage from the camera onto the geometry, then animating a new camera through the scene.
    Walter Soyka
