Activity Forums Adobe After Effects Time remap using luminance or control layer
  • Time remap using luminance or control layer
    Posted by Chris Monaco on June 6, 2018 at 4:15 pm
    Hello,
    I’m trying to figure out how to control time remapping of 45 flickering boxes by using the luminance of another layer or a script of some kind. Below is a video tutorial I found for scale but it is not exactly what I am trying to do.
    45 boxes fill a 1920×1080 comp. I want to be able to animate a ramp in random places around the 1080 comp so that the smaller boxes will be triggered only in the area the gradient lives. I also want the boxes to animate off if the gradient moves out of it’s vicinity.
    I tried controlling this with a time displacement but it doesn’t give the kind of control I am looking for. I am thinking I need help setting this up with some sort of control layer or something. Any ideas out there?
    Thank you
    https://www.youtube.com/watch?v=4OQN2mHQuD0
    Chris Monaco
    Motion Graphics and VFX Artist
    http://www.chrismonaco.tv
    Cassius Marques replied 8 years, 3 months ago 3 Members · 3 Replies
  • Steve Bentley
    June 6, 2018 at 4:43 pm
    First, each box would be a precomp and in the precomp would be a timeline of all the animations that box should do. Could you not then use expressions in the outer comp to sample the luminence at the spot a particular box sits at and then send the play head of that precomped box to the frame appropriate to that luminence level?
  • Chris Monaco
    June 6, 2018 at 6:42 pm
    Is there a way to do this with a script?
    Chris Monaco
  • Cassius Marques
    June 6, 2018 at 8:29 pm
    That’s actually pretty simple. Its just one expression. I’ve made and example: 12434_sampleluma.aep.zip
    Note that I’m guessing the luma source as greyscale, so I’m just sampling the Red value.
    Cassius Marques
    http://www.zapfilmes.com
