Activity › Forums › Adobe After Effects › time remap: need to know how to do it Right
  • time remap: need to know how to do it Right
    Posted by Andy Engelkemier on July 14, 2009 at 6:09 pm
    This has been annoying me forever, and I couldn’t find a solution by searching. Most people just want to know what it is.
    Here’s what I’m doing now so you guys can tell me what I’m missing:
    I have a composition with it’s animation. It’s 30fps if that makes a difference, not 29.97
    OK, animation is done, but now I need to extend it, so I hit Ctl+Alt+T to add a time remap.
    It comes up with the keyframes for me. I go to the time I want to extend to and hit Alt+]
    Now I have to hit ‘j’ then pageUp, insert a keyframe, and delete the last keyframe. If I skip this step it repeats a blank frame.
    First my question is, why the blank frame? And then, how do I avoid this in the future?
    At first, I thought maybe it was because it’s trying to repeat from After the last frame, so I extended all the content past the end of the layer, but that didn’t help. I do time-remaps a LOT, and it’s becoming a bit of a time waster for me.
    Andy Engelkemier replied 17 years, 2 months ago 2 Members · 2 Replies
  • Curious Turtle
    July 15, 2009 at 5:07 am
    You’re doing it right – that’s the way it is. There’s other ways to get that new keyframe in, of course, but that’s the way to go.
    I just hit O to take me to the clip’s out-point, add a keyframe there, delete the final one and get on with things.
    Cheers,
    Ben
  • Andy Engelkemier
    July 15, 2009 at 12:19 pm
    wow, that really sucks. If most people are doing that you’d think they would change the way it works, or write a script to do in an alternate way.
    I wonder if it can be done fairly easy with an expression. That way you could create an animation preset for it maybe?
    I’m not sure how to write a script that would do that. It would basically need to say, @ last keyframe value – 1 frame.
    I could get the value – 1 frame part I’m sure, but don’t know how to not run the script until the last keyframe.
