Activity › Forums › Adobe After Effects Expressions › Time Remap Loop using an Expression Control
  • Time Remap Loop using an Expression Control
    Posted by Robert Kornstein on March 5, 2014 at 2:02 am
    I am trying to set up a puppet for a character with a pseudo-3D effect. I have 8 images of the character at different angles, which, when viewed in sequence, form a 360 degree rotation around the character.
    I set up the 8 images in sequence in a pre-comp, and now I am trying to create a controller for the rotation using Time Remapping.
    How can I code an expression for Time Remapping to have it continue looping as the controller’s value goes up?
    Here’s what I have right now:
    This code is mostly non-functional. The top line makes it so that 1.00 on the slider = 1st frame of the pre-comp, and that’s about it. I don’t know how to make the If statement recursive so that it’s constantly checking to see if offset is less than 8 (right now it only loops once and then continues growing), and going less than 0 on the Slider does not rotate backwards, I’m guessing because you can’t have a negative Time Remapping.
    Does anyone have any tips that might point me in the right direction?
    offset = thisComp.layer("LI_rotation").effect("Torso Rotation")("Slider")/24;
    if (offset > 8){
    offset - 8
    else if (-8 <= offset <= 8 ) {
    offset
    else if (offset < -8) {
    offset + 8
    Dan Ebberts
    replied 12 years, 6 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    March 5, 2014 at 4:27 am
    If you use the modulus operator (%) you can create a sequence from 0 to 7 that repeats as the offset goes up, like this:
    offset%8
    If that corresponds to a frame number, then you probably need to do it this way for a time remapping expression:
    framesToTime(offset%8)
    Something like that.
    Dan
