Activity › Forums › Adobe After Effects › time remap instances
  • time remap instances
    Posted by Gon Perdigao on September 15, 2009 at 9:02 pm
    Hi there i have a footage of a girl dancing, i did an offset in time remap.
    But i want to create several instances that have some depth between them, so the only blending mode that works more or less was darken, but when i give some opacity to the layers is when everything goes bad.
    I’m a bit stuck right now.
    I’m going to send the original footage, and the renders that i made, can you point me to the right direction, or suggest a tutorial that might help me?
    Download link : https://www.sendspace.com/file/rk4keq
    Thanks a lot
    Chris Wright replied 17 years ago 2 Members · 2 Replies
  • Gon Perdigao
    September 15, 2009 at 9:18 pm
    Hi there, you’re right, in post it cost more time and money that filming again.
    But the problem is that i work in a company that everything is solve in post production, and my boss arrives and give e this job to do.
    If it was filmed in chroma it was a piece of cake, but it was not.
    So now i have to solve this, my only problem here is how to give more depth between the instances, or having a way that they don’t blend so much, so if you could help me, i would be really appreciate, if not thanks for the reply
  • Chris Wright
    September 15, 2009 at 11:37 pm
    AE CS4 came out with a new plugin called time difference that will make rotoscoping that 99% automatic.
    https://technicolorsoftware.hostzi.com/
