Activity Forums Adobe After Effects Time Remap Hold Keyframes – way to evenly distribute across time (i.e. every 2 frames)
  • Time Remap Hold Keyframes – way to evenly distribute across time (i.e. every 2 frames)
    Posted by Beth Obrien on March 25, 2020 at 8:29 pm
    Hello everyone – hope everyone is safe and healthy.
    This is my first post ever (or else in SO long I have no idea what my account email must’ve been before – I have been checking in here for over 20 years).
    MY QUESTION :
    I am putting down keyframes in time remap of video footage on the frames I want to use, then making them hold keyframes. I can not for the life of me figure out how to then easily evenly distribute those hold keyframes so they appear at equal intervals, such as every 2 frames. I thought maybe “rove across time” but this doesn’t work (which perhaps makes sense with a time remapping function). I am hoping for an expert this would be an easy solution.
    Beth
    Richard Garabedain replied 6 years, 2 months ago 2 Members · 3 Replies
  • Richard Garabedain
    March 26, 2020 at 10:40 pm
    why dont you put it in a composition with a frame rate of 2 frames a second or something like that…I dont know what you are trying to do..but the only thing i can imagine is this…
  • Beth Obrien
    March 27, 2020 at 1:09 pm
    Hi! Thanks for your response. Let me explain a little more what I am trying to do. I shot about 30 seconds of video footage that I want to convert to look like it was shot in a series of still images (like a time lapse sort of) The trick is I am going through the footage and very deliberately picking which frames I want to use. So imagine Time Remap with 100 keyframes that are *not* evenly spaced across 30 seconds (because the frames I am choosing for still shots are not evenly spaced). I want to take those keyframes than space them all exactly 2 frames apart (and make them hold keyframes). I could go and drag each one individually to two frames after the previous one, but knowing how powerful AE is I thought there must be an easier way to do this. I thought maybe “Rove Across Time” could help, but that option is not available for Time Remap keyframes.
    March 27, 2020 at 6:26 pm
    well you would think that there is a plugin for that and maybe there is…but maybe just render to a png sequence and import the images not as a sequence…but have them all be 1 frame and then keyframe assistant to line them all up. and delete the ones you dont want…its not perfect but i cant think of another way
