Activity Forums Adobe After Effects time re-map speed info
  • time re-map speed info
    Posted by Ken Pugh on August 31, 2008 at 9:35 am
    I’ve just recently upgraded to CS3 after many years with AE7 – having to relearn quite a bit about the interface in the process….. in particular – I want to apply speed re-maping. Just a simple ramp. I’ve figured out how to access the graph editor but I can’t see where the speed info has gone. In the old version you could just toggle the triangle in the timeline and a graph would open up with all the data you need. In CS3 it seems you can’t have the timeline and the graph together, as opening the graph replaces the timeline, most annoying, but worse in graph mode I can’t see how to get the numeric data. I want to know how fast the footage is traveling, eg 55% or 88%. Could someone enlighten me where this info has gone?
    Much obliged, I’m sure I’ll love CS3 as much as 7 once I get the hang of this interface!
    Cheers,
    Ken.
    Ken Pugh replied 18 years ago 1 Member · 0 Replies
  • 0 Replies
