Activity Forums Adobe After Effects Time overlapping animated text
  • Time overlapping animated text
    Posted by Seth Parker on September 16, 2010 at 9:02 pm
    I have a text layer setup with a Range Selector animation that causes each character to rotate and fade into position individually. I kept thinking that the animation wasn’t quite as fluid as I wanted it to be and then I realized that each character was waiting on the previous character before its animation started. What I would like is for the animations to overlap a little. For instance, if I have word, “ABCD,” as A is halfway through its rotation, B starts to rotate into position.
    I’m almost afraid that this isn’t even possible with the selector seeing as its basing the animation on a percentage of the letters, as there is never a percentage that includes multiple characters…
    Thoughts or suggestions?
    Roland R. kahlenberg replied 16 years ago 2 Members · 4 Replies
  • Seth Parker
    September 16, 2010 at 9:25 pm
    I ended up changing shape of the Selector to Ramp Up and after adjusting some keyframes that did the trick. I would’ve liked to adjust the timing a bit more, but this animation looks smooth enough.
  • Roland R. kahlenberg
    September 17, 2010 at 2:35 am
    The Ramps do a nice job. When using the Ramps, it’s a good idea to animate the Range Selector’s Offset parameter instead of animating the Start and/or End parameters.
    Cheers
    RoRK
    AE templates for sale and rental. Click here for more
  • Seth Parker
    September 17, 2010 at 4:51 pm
    The problem I’m noticing just using Offset is that all the letters rotate in at the same time, rather than sequentially.
    September 17, 2010 at 5:15 pm
    It’s a matter of taste and preference and what’s required for the job on hand.
    With Ramp Up or Ramp Down, I normally set up as such –
    Start = 0
    End = n (where n is the total number of characters or percentage)
    Offset = requires keyframing
    The first Offset keyframe value is the negative of n (as above). The second keyframe value for Offset will be n.
    The set Ease Low to 100% for a nice Ease In effect. And also try Ease High at -100%. Switching on Randomize Order sometimes makes things look nices. Add some Motion Blur for extra garnishing.
    HTH
    RoRK
