Activity Forums Adobe After Effects Expressions Time of last key
  • Posted by Stuart Gibb on November 9, 2017 at 12:13 pm
    Hello,
    I am trying to determine the time at which my trim path shape reaches 100% complete.
    I am able to determine the current value using:
    thisComp.layer(“Shape Layer 1”).content(“Shape 1”).content(“Trim Paths 1”).end.value
    How do I combine the above with the .key/.time to determine the time of the last key i.e. 100% complete?
    Stuart
    Dan Ebberts replied 8 years, 9 months ago 2 Members · 3 Replies
  • Dan Ebberts
    November 9, 2017 at 4:43 pm
    Try this:
    prop = thisComp.layer(“Shape Layer 1”).content(“Shape 1”).content(“Trim Paths 1”).end;
    prop.key(prop.numKeys).time
    Dan
  • Stuart Gibb
    November 11, 2017 at 8:48 am
    Excellent Dan, thank-you.
    Next question if I may, I am using your up-down timer expression.
    The inpoint on my text layer is > 0.
    Prior to the inpoint, I want to set the text to read “00:00”.
    How would I do this? I can’t determine the value of time prior to the text layer’s inpoint?
  • Dan Ebberts
    November 11, 2017 at 10:40 pm
    I’m not at all sure I understand the question, but maybe like this:
    clockTime = Math.max(rate*(time – inPoint),0);
    Dan
