Activity › Forums › Panasonic Cameras › Time of day Sync Timecode
  • Time of day Sync Timecode
    Posted by Fargoross on April 10, 2006 at 3:47 pm
    Hello,
    We have two Panasonic 100A camera’s that we are using for a studio shoot.
    We are trying to find a way to sync the timecodes so our editor can edit the footage easily.
    Our edit system does not have firewire, so no Ubit data from the camera can be carried over.
    What I would like to do is use Time of Day as timecode.. is this possible?
    or would we have to jam sync the cameras after every scene/take, and start them up
    at the same time (which seems like it would get too complicated)..
    Really I would like the camera to base the time code on time of day whenever its recording
    (we already have the time of day sync’ed and set up in the cameras)
    Thanks so much for the help!
    Sincerely,
    Ross Hendrickson
    Editor/Photographer
    Video Arts Studios
    Fargo, ND
    Ken Pugh replied 20 years, 5 months ago 6 Members · 7 Replies
  • 7 Replies
  • David Battistella
    April 10, 2006 at 8:07 pm
    you could try this, but I doubt that it is frame accurate.
    You maight be able to get close and then figure out the offset in FCP when you gang sync the clips to do the line cut.
    One thing you can do is record TC to audio ch 2.
    David
    Peace and Love 🙂
  • Noah Kadner
    April 10, 2006 at 11:58 pm
    if your using all DVX’s.. use free run timecode. Put all cameras on a counter and set it with the remote control all at the same time. You will get true sync on all cameras even when you turn them off and change batteries.
    -Noah
  • Kmac444445
    April 11, 2006 at 1:39 am
    Gentlemen,
    Thank you very much. Great input and a very manageable one, finance-wise!
    Three of the four cameras are DVX’s. Interestingly, one DVX100, one DVX100a, and one DVX100b.
    Do you know of any incompatibility issues I should be aware of between the three models, in terms of synch?
    As an aside: The fourth camera will likely be a Canon XL2. Any suggestions for synching this? I suppose we could do a rough and dirty synch by setting that cam to FREE RUN at “about” the same time, then live with it in post. Any ideas, however, to be more exact?
    Again, thank you,
    Kevin
  • Barry Green
    April 11, 2006 at 7:16 am
    To be more exact, you can try filming the XL2’s timecode display on one of the other cameras. That way your editor can compare the actual timecode to the filmed timecode and hopefully come up with a constant offset.
    Also, ensure that you’re using the same mode (DF or NDF) on all cameras.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Kmac444445
    April 12, 2006 at 1:08 am
    Thanks Barry, I appreciate the suggestion.
    Call me novice: What does “DF” and “NDF” refer to?
    (You suggested: “Also, ensure that you’re using the same mode (DF or NDF) on all cameras.”)
    Thank you again.
    kevin
  • Barry Green
    April 12, 2006 at 2:09 am
    “drop frame” and “non drop frame”. Two different numbering systems for how the frames get counted. Doesn’t make a whole lot of difference which one you use, just so long as everyone’s using the same system. Ask your editor which one they prefer.
  • Ken Pugh
    April 23, 2006 at 12:04 pm
    As a follow on to this discussion, I think it’s almost part of the same thread – apologies otherwise, I’m thinking of buying two AG-DVX100B camcorders for shooting a live event. Can I use the firewire output from my Sony DSR570 to set the first AG-DVX100B, then use that to set the second AG-DVX100B, set t/c all in free run, disconnect the f/w cables and expect the cameras to be locked in sync across start stops and battery changes later in the edit?
    Ken.
