Activity › Forums › Apple Final Cut Pro Legacy › Time Machine and Media on same drive
Posted by Patrick Simpson on September 23, 2009 at 2:56 amIs it a bad idea to use an external FW hard drive for both Time Machine backup of the system and Final Cut (and other) media? Should the FW hard drive be partitioned first?
20″ intel iMac, 2.66 GHz, 4GB ram
View my reel – http://www.youtube.com/patrickdsimpsonScott Sheriff replied 17 years ago 3 Members · 6 Replies -
John Pale
September 23, 2009 at 3:17 amDon’t do it. You don’t want FCP and Time Machine writing to the same drive simultaneously. Will definitely affect performance.
Partitioning will not help. It’s still the same physical drive.
Get a second FW drive. They are cheap.
Patrick Simpson
September 23, 2009 at 3:25 amI’m cheap too.
Can I schedule Time Machine to only backup at night or something? Maybe there are settings in Time Machine to avoid issues?
View my reel – http://www.youtube.com/patrickdsimpson -
John Pale
September 23, 2009 at 3:40 amNo. But you can turn Time Machine off while you edit.
Still don’t think its a good idea. you are putting lots of wear and tear on the drive you use to back up all your data. But if thats not important to you, by all means. -
Scott Sheriff
September 23, 2009 at 4:07 amDon’t waste a FW drive on Time Machine if you are cheap. Total overkill. Go get a USB ‘My Book’ for Time Machine, and use the FW for just for media.
I think it is bad mojo to co-mingle system and media on the same drive. -
Patrick Simpson
September 23, 2009 at 4:37 amThanks for the info, it helps a lot.
How much space do I need for Time Machine? I suppose this varies a lot; I have a 300 GB system drive with probably 80 GB of data that I’d actually back up.
Scott Sheriff
September 23, 2009 at 5:38 amIMHO
I think it should be as large as your system drive, so I would go for a 500mb, if they don’t have a 300. The Time Machine will back up everything, then make periodic back-ups of the changes since the last. The more back-up space you have, the farther ‘back into time’ you can go to recover old material. Once the drive is full, it will start over-writing the oldest data. You can also exclude things from the TM back-up like web caches and other non-essential space wasters, which will help delay the over-write of past back-ups.
