Activity Forums Boris FX time line,and poj settings
  • time line,and poj settings
    Posted by Arthur489 on December 16, 2007 at 9:14 am
    Hi, when I import a new media in the time line (a 6 sec footage for ex)my time line lenght is only 1 sec, I tryed to chenge the project or comp settings to 6 sec but nothing…Do I have to import my media in another way ?(I was trying to follow the tut on motion stab.)
    thanks a lot
    Arthur
    Alan Mccormick replied 18 years, 9 months ago 2 Members · 3 Replies
  • Alan Mccormick
    December 16, 2007 at 10:00 am
    Arthur, if you are using FX standalone or keyframer then you can import a “movie” and change the duration length but remember that you can only extend the duration of the movie clip to the actual original maximum length. After that whatever is in the track below will be shown. If the duration is less than the max length then you will see that shortened version.
    If you open up Boris via your NLE then you cannot alter the duration, you can only do that within your NLE prior to opening Boris.
    Regards
    Alan
  • Arthur489
    December 17, 2007 at 2:35 am
    Ok now I understand,Thanks,for your help, I m following the tutorials and pdf to understand a little beat more of this powerfull software,so I will maybe come back here for more help.
    thanks
    Arthur
  • Alan Mccormick
    December 17, 2007 at 5:20 am
    No problem, I am learning too 🙂
    Regards
    Alan
