Activity › Forums › Boris FX › time line won’t play in Red
  • time line won’t play in Red
    Posted by Axel Andy on March 12, 2007 at 7:59 pm
    I am new to Red & I’m using 3.0.04.
    Often, my boris timeline won’t play when I launch it from the host (avid xpress dv). I’ve tried clearing the cache and sometimes that will make it play – but not always. I’ve checked the preferences to make sure they match what I had with Boris FX – because I didn’t have this problem with fx.
    My graphics card is a Matrox Millenium and doesn’t support the open gl thing so that’s turned off.
    I can play the boris timeline in the stand alone engine and if I get out of Avid and come back in, then re-launch boris red from the host, it usually works…for a short period of time – then stops playing again.
    I can “scrub” the TL but just can’t get it to play.
    K
    Peter Mcauley replied 19 years, 6 months ago 2 Members · 5 Replies
  • Peter Mcauley
    March 12, 2007 at 8:42 pm
    You should probably upgrade to RED 3.0.4 … that’s the most recent free updater for this version of the software. RED 4 is the latest version and is much more powerful than RED 3 but you should at least be at RED 3.0.4. This is a free update from the BorisFX web site and can be downloaded from here:
    https://www.borisfx.com/updates/
    Have you tried to make a preview to RAM? You may find that more efficient than just pressing the play buttons.
    Cheers,
    Peter.
  • Axel Andy
    March 12, 2007 at 9:02 pm
    I am at Red 3.0.4. Red 4 kept crashing my system.
    K
  • Peter Mcauley
    March 13, 2007 at 3:36 pm
    Perhaps someone from our support team can help you to figure out why RED 4 was crashing your system. I can only encourage you to send an email to the team at support@borisfx.com and I’m sure that they will be able to resolve the problem.
    Cheers,
    Peter.
  • Axel Andy
    March 13, 2007 at 5:20 pm
    Red 4.0 isn’t supported with Avid Xpress DV 3.5. This from the Boris team.
  • Peter Mcauley
    March 13, 2007 at 5:58 pm
    Yes, that’s correct – and that would explain why you are having problems. The current revision for Avid Xpress is I think 5.6 so you would have to upgrade the host in order for RED 4 to work. Sorry.
    Cheers,
    Peter.
