Activity Forums Apple Final Cut Pro Legacy time line settings, render settings, exporting settings
  • time line settings, render settings, exporting settings
    Posted by Jonathan Young on May 5, 2008 at 1:55 pm
    would i benefit quality wise by working in the DV 50 timeline with my DV NTSC footage ? or what if I worked in the regular DV NTSC timeline, or if I rendered in a 8 bit or 10 bit uncompressed ? this would not be for the web, just for DVD. The main question I am asking is, would any other timeline setting, render setting, or exporting setting, enhance the quality of my DV NTSC video or compress it less ?
    Shane Ross replied 18 years ago 4 Members · 4 Replies
  • Rafael Amador
    May 5, 2008 at 2:29 pm
    Hi Jonathan,
    If you just export your DV footage as DV50 or 8/10b Unc you only will get a bigger file. No quality improvement.
    But, if you use a Chroma Filter (Nattress “Chroma Smoothing/Sharpening”, Nattress Nicer, Apple: 4.1.1,.) on top of your DV footage, a bit of Color Correction and you export in 10b Unc, your pictures will look MUCH BETTER.
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • David Roth weiss
    May 5, 2008 at 2:42 pm
    However[Rafael Amador] “If you just export your DV footage as DV50 or 8/10b Unc you only will get a bigger file. No quality improvement.”
    However, if you change the Compressor to DV50, 8-bit, 10-bit, or ProRes your text and graphics will be not suffer the consequences of DV compression and will be considerably better.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Rafael Amador
    May 5, 2008 at 4:16 pm
    [David Roth Weiss] “However, if you change the Compressor to DV50, 8-bit, 10-bit, or ProRes your text and graphics will be not suffer the consequences of DV compression and will be considerably better.”
    Absolutely right.
    JVC DTV-17″
  • Shane Ross
    May 5, 2008 at 5:59 pm
    However however…do this AFTER you have finished editing. Otherwise you will be rendering every clip you drop in the sequence. Oh, unless you have FCP 6 and a nice fast machine. But typically I suggest editing native, than copy and pasting the sequence into a DV50 sequence and rendering right before you export.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
