Activity Forums Apple Final Cut Pro Legacy Time Line Rendering problems.. please help
  • Time Line Rendering problems.. please help
    Posted by Paula Stein on March 6, 2007 at 2:24 am
    I have a project already on a drive that came from a earlier version of FCP (I have 5.1)
    Here is the problem…when editing, I have to consistantly render everytime I make a edit change.
    The item formats show the sequences to be 29.97 fps, frame size to (960×720) compressor DVDPRO HD 720p60
    The camera was Panasonic P2 card set up.
    Any ideas? ..have to render everytime I make an edit~!
    Paula Stein replied 19 years, 6 months ago 2 Members · 2 Replies
  • Shane Ross
    March 6, 2007 at 3:24 am
    Wrong frame rate. Should be 59.94 if the footage is 720p60. 720p30 is 29.97.
    Easiest thing to do is Choose the 720p60 Easy Setup, delete the current sequence and make a new one. If that doesn’t work, try 720p30, then 720p24.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Paula Stein
    March 6, 2007 at 3:43 am
    It worked!
    720p24 is the one..
    Thank you so much Shane..
