Activity › Forums › Avid Media Composer › time line plays in the center of the composer window
Posted by Evs-rootbeer on May 16, 2007 at 5:58 pmwhy does my time line plays in the center of the composer window and how do i fix that… it’s over lapping the source window?thanks andy
Evs-rootbeer replied 19 years, 3 months ago 3 Members · 7 Replies -
Jon Zanone
May 17, 2007 at 12:50 amI’m not sure I follow – the timeline window is over your source monitor? Is it an issue of dragging your window out of the way, or am I missing something?
Jon
“The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
Evs-rootbeer
May 17, 2007 at 4:09 pmthank you there are two monitors, the left plays the clip you select, the right plays what’s in the time line. my time line plays in the middle of the two windows partially blocking both. thanks for the help. andy
Chaz Shukat
May 17, 2007 at 4:44 pmHave you tried clicking on the timeline and then selecting “home” from the windows menu?
Chaz S.
Evs-rootbeer
May 17, 2007 at 5:15 pmi’m not saying that the time line window is on top of the composition window. i’m saying that the video that the timeline represents which is supposed to play back on the right half of the composition monitor. plays back in the middle obstructing the other two. it’s like a monitoring problem. not a how the window are laid out problem. thank you. andy
Chaz Shukat
May 17, 2007 at 7:40 pmIt sounds like you have a pop-up window open. Have you tried closing that window?
Chaz S.
Jon Zanone
May 18, 2007 at 12:17 am…and whats your video card/CPU/memory/OS? Sounds also like a redraw issue. Any chance you are using an ati video card?
Jon
Evs-rootbeer
May 18, 2007 at 1:52 pmyes it was a re-draw issue. i had to change my monitor resolution to 1020 i believe… and it fixed it. thanks for pointing me in the right direction
