Time-line is red – my video has disappeared
I’ve searched the Premiere Pro Forum archive, but cannot find the answer to a problem I’m experiencing with a project.
I opened a nearly finished project and found the time-line all ‘RED’. There is no video nor sound, although all the edit points are there. Supered over the red it says ‘Media Offline’ in both English & Japanese. Actually, I should clarify…there is ‘SOME’ sound, a bird sfx from a CD and a also a couple of titles, but all the soundbites and video are gone. A backed up version on an internal drive is the same way.
The actual project is located on one of three external harddrives that I have. The drives are attached to a 4 port USB box which goes to the computer via a single USB cable. I also have a short USB cable connected to this same box, which I use to add photos from my small jump drive. In fact, I THINK that’s when I noticed my large harddrive had changed its drive letter from G: to J: Evidently, the jump drive had the same letter? I’m not sure.
The reason I say ‘think’ is because about this same time I also added 2 gigs of RAM to the computer and changed my video card (the old one went bad.) Things have generally been messed up since then. I’ve had to re-zize my monitors, project timelines etc.
The big question is: how do I get my partially edited video project back? Do I change my external harddrive letter back to G: If so, how do I do that without messing up the project?
In the past, I have noticed a couple of OTHER projects that turned to red on the timeline. Fortunately, they were completed…this one is not. I’m wondering if I’m doing something fundamentally wrong, as I operate the system. Any help will be appreciated. Thank you.
Wendall
Filmmaker 20
