Activity Forums Adobe After Effects Time line import From Premier 2.0 to EF 6.5
  • Delete
    May 7, 2007 at 8:12 pm
    6.5? not entirely sure, but you should be able to select the elements you want in PP2 and copy them via “edit-copy” or “ctrl-C” and simply paste them into a new composition in AE. That’s how I do it. It’s been a while since i used 6.5… just try it.
