Activity › Forums › Adobe Premiere Pro › time lapse with gopro
Posted by Matt Warthen on July 1, 2013 at 5:33 pmI shot a time lapse video with my gopro 3 and wanted to put it together with premiere pro 6. It’s came out as about 4,500 jpegs. When I import them I only see the middle of the image because each jpeg is 3,000 x 4,000. I can zoom out on each individual jpeg, but I don’t know how to do it for the whole sequence.
Chad Smith replied 11 years, 10 months ago 4 Members · 5 Replies -
Trent Happel
July 11, 2013 at 1:32 amIs your Sequence frame size the same as your files? If you create a Sequence of the same size (3000×4000), then you should not run into this issue with your files. You could even drop one file on to the ‘New Item’ icon on the bottom right of the Project panel and it will create a new Sequence based upon the file frame size.
If you want to see the entire image in a smaller frame size Sequence, you can select all of the files in the Sequence, right-click and select ‘Scale to Frame Size’
Trent Happel
Matt Warthen
July 11, 2013 at 12:02 pmThanks. I have since figured it out. I was importing them as jpegs and not as an “image sequence”. Thanks though!
Chad Smith
October 20, 2014 at 5:05 pmI have done several imports of GoPro footage (stills) using the checked “Image Sequence” box to create time lapse footage, but now I’m have a problem with the one I’m currently trying to do. It is just over 3000 images and the GoPro named them sequentially, though it chose random numbers, often jumping a few hundred then continuing on. Obviously renaming 3000 files seems daunting, so I’m wondering if anyone can shed some light on my problem. When I do the import I get only the first frame (:03 secs) and nothing I do rectifies this. It’s totally bizarre, considering I’ve done this at least 50 times before with no problem.
Suggestions? -
Steve Brame
October 20, 2014 at 5:45 pmNot sure how files can be named sequentially with random numbers. Sure would like to see a screen grab of that.
At any rate, if you decide that you need to rename the files, a utility like Winsome File Renamer will make it a breeze, allowing you to set rules for renaming lots of files truly sequentially, and viewing a preview of the renamed files before actually hitting ‘Go’.
Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
“98% of all computer issues can be solved by simply pressing ‘F1’.”
Steve Brame
creative illusions Productions -
Chad Smith
October 20, 2014 at 5:50 pmI got it figured out. It seems that each time I stopped the GoPro, it re-started with a new 1000’s (i.e.: jumped from 4,000 to 5,000) and Premiere Pro only batches each set within the same sequence and stops when there’s a jump. Thus, I did an individual import for each section and it worked fine.
