Activity Forums Apple Final Cut Pro Legacy Time Lapse Stutter in FCP 5.0.4
  • Time Lapse Stutter in FCP 5.0.4
    Posted by Kevin J. railsback on March 18, 2006 at 1:38 pm
    I’ve been shooting time lapse clloudscapes with my HVX200.
    It seems that if I playe the QuickTime file on it’s own after it’s imported via FCP, it plays very smoothly.
    Once I export the timeline in FCP and I play it back, the time-lapse now stutters or jerks. It doesn’t play back smooth. If I go back and open the file on it’s own without being on a timeline, it plays smoothly.
    So something from exporting from the timeline is doing something to lose the smoothness.
    I’m using the easy setup for DVCPRO HD 720p/24
    As far as I can tell, everything else plays back normally.
    David Bogie replied 20 years, 6 months ago 2 Members · 1 Reply
  • David Bogie
    March 20, 2006 at 4:48 pm
    You will need to define jerky, smooth and stutter. Also, where are you seeing this problem? The Viewer is just a QT player window and will run anything QT can handle. The Canvas, however, is a window into your sequence and wil only display the sequence settings to the extent your machine is capable.
    Timelapse, by its very nature has some glitches.
    bogiesan
