Activity Forums Cinematography Time-lapse SDX-900-best way?
  • Time-lapse SDX-900-best way?
    Posted by Todd Gillespie on January 12, 2006 at 7:41 pm
    Hi All,
    I’m trying to figure out the best way to try to tape some time-lapse footage with an Panasonic SDX900?
    I haven’t used this feature on the camera, but I don’t have the RAM option either (next year’s budget)
    I believe the camera can tape 10-20secs at a time interval that you can set. But what I’m wondering about is how you work with it in post?
    Even if you recorded time-lapse footage with this feature, then you would still need to spend a lot of time pulling out individual frames and lining them up?
    I thought about just rolling off a couple of hours of footage (in realtime), then compressing it down…
    Any thoughts?
    Todd at UCSB
    Television Production
    David Jones replied 20 years, 7 months ago 2 Members · 1 Reply
  • David Jones
    January 13, 2006 at 2:12 pm
    I use a little program called BTV Pro for doing things like time lapse.
    You can run it from a laptop connected to the camera, or record the footage to tape and then transfer later.
    You can taylor capture options to fit the type of time lapse you are doing.
    I have found that 1 frame per second gives a nice look.
    Good Luck!
