Activity › Forums › Apple Final Cut Pro Legacy › Time Lapse plug in for FCP?
Posted by Peter Hall on August 22, 2008 at 8:56 amI have some long stationary takes of cityscapes that I would like to edit into a time lapse effect without doing the tedious work. Is there a plugin that can help with that? The source material is HDV 1080/50i from mini dv tapes and I am using FCP 5.14
Steve Eisen replied 18 years ago 5 Members · 7 Replies -
Simon Hustings
August 22, 2008 at 11:25 amYou still have to capture the footage as normal, lay it down on the timeline and use the Speed option from the Modify menu; easiest method and one I use frequently.
Simon. -
Rafael Amador
August 22, 2008 at 1:50 pm -
Alex Elkins
August 22, 2008 at 4:33 pmDoes the Nattress one allow you to actually capture as a timelapse?
Peter Hall
August 22, 2008 at 4:52 pmthanks Simon, but I’m really looking for application that allows you to select bursts of selected frames at periods of pre determined times…..
Rafael Amador
August 23, 2008 at 1:40 amThe Nattress is an FC effect.
You apply it in the FC time-line, on footage that you have already captured.
Rafael -
Steve Eisen
August 23, 2008 at 3:18 amCHV Random Frames
https://www.chv-plugins.com/cms/Fx-Script/Time-collection/Time-collection.php?navanchor=1010027Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group
